Smart Psu (galaxy) - Fuse Blown
Hi,
The fuse on the Smart PSU (I believe it is labelled as F1 supplying 12V2) had blown and so I replaced it. However on powering up the panel the fuse blew again. I would be very grateful if someone could assist on this one - faulty module or PSU? Is this a known problem?
Kind Regards
Craig
www.wiinetwork.co.uk - Nintendo Wii Worldwide User Map
There is obviously a fault on the system, something is possibly shorting out.
Is there any damaged cable?
Cant spell
Guest rjbsec
Is there another way of checking for a short other than continuity check on ALL cables?
"ALL cables" - How many do you need to check?
Whip ya aux out, slap a meter (ohms) on it, should read infinity if it don
10 zones - I assume from the response I only need to check the +12 cables?
Guest rjbsec
How did you get yourself in this situation?
QFA
I think HandyAndy needs to be resurrected :hmm:
