Smart Psu (galaxy) - Fuse Blown
A engineer should be able to locate the faulty cable in 5 mins.
Guest rjbsec
But rectifying it after building works might well take a little longer!
Now that would be a first!
8 on the PSU two on the G60.
You did say the fault was on a smart PSU and not a G60.
BTW G60 has 12 onboard and if it has a smart PSU which is a further 8 then it has 20 in the panel, so what is the fault on a smart PSU or the control panel board,
Wheres Handy Andy when you need him......
QFA
www.nova-security.co.uk
www.nsiapproved.co.uk
But finding the damaged section of the cable could take considerably longer.
My original post was
The fuse on the Smart PSU (I believe it is labelled as F1 supplying 12V2) had blown and so I replaced it. However on powering up the panel the fuse blew again. I would be very grateful if someone could assist on this one - faulty module or PSU? Is this a known problem?
I don't know where the fault is, that is why I'm asking the professionals on this forum if they may be able to assist.
www.wiinetwork.co.uk - Nintendo Wii Worldwide User Map
