jig Posted June 9, 2006 Share Posted June 9, 2006 Hi, I have a Dedicated Micros Digital Sprite DX16C Multiplexer, I have it setup with three internal and two external housed cameras. I do not have a manual but trying I need to adjust the picture, how can I select the highest picture quality? Currently the picture is 'whitened' and quality is poor . (I have checked each camera seperately and the pictures from each camera is fine). How do I do this? Cant find the option on the menu banghead All help and advice is greatly appreciated. Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10884-help-dm-dvr-picture-adjustment/ Share on other sites More sharing options...
Guest Posted June 9, 2006 Share Posted June 9, 2006 sounds more likely camera/cabling problem than MUX.. usually you cant and don't "adjust picture" with MUX. how did you determine the picture quality? did u connect the incoming cable instead of mux input to monitor? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10884-help-dm-dvr-picture-adjustment/#findComment-102259 Share on other sites More sharing options...
jig Posted June 10, 2006 Author Share Posted June 10, 2006 sounds more likely camera/cabling problem than MUX..usually you cant and don't "adjust picture" with MUX. how did you determine the picture quality? did u connect the incoming cable instead of mux input to monitor? Hi, The cable was plugged directly into a tv via bnc and it showed a good picture, but when going via the dvr we then see the loss in picture quality which is why I dont believe it is the cameras or the cables. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10884-help-dm-dvr-picture-adjustment/#findComment-102331 Share on other sites More sharing options...
ian.cant Posted June 10, 2006 Share Posted June 10, 2006 Hi,The cable was plugged directly into a tv via bnc and it showed a good picture, but when going via the dvr we then see the loss in picture quality which is why I dont believe it is the cameras or the cables. Its a termination issue! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10884-help-dm-dvr-picture-adjustment/#findComment-102369 Share on other sites More sharing options...
Guest Posted June 10, 2006 Share Posted June 10, 2006 well - there is something rotten in this since jig mentions MUX and a DVR in the same context.. jig - are you having a mux or an dvr or are you recording on to the dvr through mux??? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10884-help-dm-dvr-picture-adjustment/#findComment-102381 Share on other sites More sharing options...
jig Posted June 10, 2006 Author Share Posted June 10, 2006 well - there is something rotten in this since jig mentions MUX and a DVR in the same context..jig - are you having a mux or an dvr or are you recording on to the dvr through mux??? Apologies for the confusion as stated above it is a Dedicated Micros Digital Sprite DX16C Multiplexer but this model has a 2x75gb harddrive and so does that make it a dvr?? Its a termination issue! Not sure what you mean, do yoy meean the bnc need crimping better? please explain? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10884-help-dm-dvr-picture-adjustment/#findComment-102383 Share on other sites More sharing options...
Guest Posted June 10, 2006 Share Posted June 10, 2006 no.. terminating means that signal is terminated to an pure R equivalent of an Z of the cable. DM is an DIY supplier so i am afraid that no one here is able to help you.. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10884-help-dm-dvr-picture-adjustment/#findComment-102392 Share on other sites More sharing options...
spider Posted June 10, 2006 Share Posted June 10, 2006 Go to DM web site for the manual, it is most likeley to be a termination issue Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10884-help-dm-dvr-picture-adjustment/#findComment-102394 Share on other sites More sharing options...
jig Posted June 10, 2006 Author Share Posted June 10, 2006 Go to DM web site for the manual, it is most likeley to be a termination issue Thanks for all the help everyone,but still not sure what is meant by a 'termination issue' Also cant find the manual for this model on DM's website, can anyone point me in the right direction? Jig Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10884-help-dm-dvr-picture-adjustment/#findComment-102398 Share on other sites More sharing options...
PJF Posted June 10, 2006 Share Posted June 10, 2006 Press and hold menu, then search for the termination bit. Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/10884-help-dm-dvr-picture-adjustment/#findComment-102402 Share on other sites More sharing options...
