Double Knock
whibbs
  gramymos said:
double knock..no no no...thats nearly as bad as soak test..if
steady mate, or you'll have big bad 'bellman' after you :cry:
:P
regs
alan
Never used it & never will. If the system is designed correctly then it should never be used. If there is a problem with a detector, then why not upgrade it to something that can cope.
Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
