whibbs Posted June 10, 2006 Posted June 10, 2006 does any one know of of a good outdoor pir as i have a large job coming up it has a round 20 zones and 4 areas thanking of the preimer 48 panel and i have been told by my suppler to use the intellisense dt900 dual pir with micro as these are good outdoor pirs does any one have any comments Wayne Hibbs
arfur mo Posted June 10, 2006 Posted June 10, 2006 does any one know of of a good outdoor pir as i have a large job coming up it has a round 20 zones and 4 areas thanking of the preimer 48 panel and i have been told by my suppler to use the intellisense dt900 dual pir with micro as these are good outdoor pirs does any one have any comments hi whibbs, i have used GJD gear for cctv triggers and external lighting, gartec offer some reasonably priced extermnal ones but imo outside alarm detection systems based on motion detectors are best avoided - herds of cats - flocks of seaguls because staff leave their sadwiches in the protected area = no thanks better to use redwall, buried sensor or siezmic depending on site requirements regs alan If you think education is difficult, try being stupid!!!!
ian.cant Posted June 11, 2006 Posted June 11, 2006 does any one know of of a good outdoor pir as i have a large job coming up it has a round 20 zones and 4 areas thanking of the preimer 48 panel and i have been told by my suppler to use the intellisense dt900 dual pir with micro as these are good outdoor pirs does any one have any comments Someone has been taking the piss out of you, that detector is certainly not for external use.
Guest ALSEC Posted June 11, 2006 Posted June 11, 2006 You could put a small umbrella over it - what environmental class would that be?
cdosrun Posted June 11, 2006 Posted June 11, 2006 I can't testify to the quality, but I like the look of the Rokonet WatchOUT range. They have a quad and a dual-tech (with 2xPIR and 2xMicrowave built in). http://www.rokonet.com/category.asp?plid=2&fmid=34 Any statement made or information provided in this post are the mere opinions of the author, and no inferrence is to be made as to the quality of information nor should any reliance be placed upon its contents.
arfur mo Posted June 11, 2006 Posted June 11, 2006 I can't testify to the quality, but I like the look of the Rokonet WatchOUT range. They have a quad and a dual-tech (with 2xPIR and 2xMicrowave built in).http://www.rokonet.com/category.asp?plid=2&fmid=34 i've not used this model of detectors, rokonet imo are excellent in the internal market, i'd suggest what i do, buy one or two and field test it at you home. regs alan If you think education is difficult, try being stupid!!!!
