south_side Posted June 11, 2006 Posted June 11, 2006 hi all, I need your help I have just installed the above system with 3 pyronix PIR's. The problem is that when the system is set off in testing conditions, the bell doesn't sound. I have tested the tamper loop with a multimeter and that is fine but if I break the loop the tamper light on the keypad lights but no sound from the bell box. If the alarm is set and then set it off, again no sound but Now this is what is what I don't understand, IF the PA is activate the bell works ?????????? Please, I need your help ! I have wired the control panel to the bell box based on ventcroft's instructions and I can give the wiring diagram if necessary. Any help and advice is greatly appreciated Thanks
Deltaseven Posted June 11, 2006 Posted June 11, 2006 hi all, I need your helpI have just installed the above system with 3 pyronix PIR's. The problem is that when the system is set off in testing conditions, the bell doesn't sound. I have tested the tamper loop with a multimeter and that is fine but if I break the loop the tamper light on the keypad lights but no sound from the bell box. If the alarm is set and then set it off, again no sound but Now this is what is what I don't understand, IF the PA is activate the bell works ?????????? Please, I need your help ! I have wired the control panel to the bell box based on ventcroft's instructions and I can give the wiring diagram if necessary. Any help and advice is greatly appreciated Thanks It sounds like you have a bell delay or 'Sounder Delay on entry' enabled. I don't know the programming location for that - but have a look in your manual. I am sure some more advice will follow from people more experienced with these panels! D7
norman Posted June 11, 2006 Posted June 11, 2006 30 second dual ply, option 60 something 64? Disable it. Nothing is foolproof to a sufficiently talented fool.
south_side Posted June 11, 2006 Author Posted June 11, 2006 30 second dual ply, option 60 something 64? Disable it. Thanks for that, I'll give it a go and let you know !
