Bell Box Fitting
Hello There,
I was wondering...
When you fit bell boxes..Do you drill from the outside to in or do you drill inside to out??
If you drill from outside inwards.. How do you know where its going to come out??
If you drill from inside outwards.. Where do you usually go to drill out to and how do you know it will come out in a good location on the outside??
Its something that is bugging me a lot..
Thanks Guys
Hello There,
I was wondering...
Thanks Guys
It takes time, practice and a few hair raising moments. The more you do it the better you get.
The older I get, the faster I was.
Can't argue with that.
Usually. ;)
Hey.
Thanks for your replies.
So do you usually drill from or to the loft?
Most of the bell boxes ive seen are near/around a bedroom window rather than the loft... Where would the wiring come out then? In the bedroom and plastered?
Thanks for your replies and sorry to be questioning about this.
Agreed as above.
I had an electrician talking to me today... He quoted "They are a bugger them alarm systems".. :no:
Me - "That depends on if you actully know what your doing" :whistle:
The above is my personal opinion and not that of my employer or anyone else.
Almost always in to the loft.
Boxes near windows are often DIY or fitted by electricians.
but could be a fitted wardrobe there too. :rolleyes: so drill shaft makes nice coat hanger rail
regs
alan
Hey.
I usually drill up into the loft from outside unless there's a good reason not to. Same with apexes, just check before you drill that there's not a water tank or something daft right behind the wall. I don't like bell boxes near windows. It looks **** and it usually means the cable has been stapled behind the curtain or around the window frame.
Trade Member
