Guest Posted June 15, 2006 Posted June 15, 2006 Was on a site in hull this week to put a digi on, nobody knows the telephone no. & we need it to set up downloading, I can ring my mobile on it but the line number is set up to withhold automaticaly, Does anybody know how to test the line on this exchange?? eg. exchange rings you back repeating the line number to you?? Tez
Monteey Posted June 15, 2006 Posted June 15, 2006 Try putting 1470 in front of your mobile number when you ring, it should come up with the number then Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
Guest ALSEC Posted June 15, 2006 Posted June 15, 2006 Try putting 1470 in front of your mobile number when you ring, it should come up with the number then Not going to give away the sacred 5 digit no for line test then Mark??
ian.cant Posted June 15, 2006 Posted June 15, 2006 Hull doesnt have BT, the telephone network in Hull is run by Kingston Communications!
norman Posted June 15, 2006 Posted June 15, 2006 Not going to give away the sacred 5 digit no for line test then Mark??I thought it was common knowledge!Hull doesnt have BT, the telephone network in Hull is run by Kingston Communications!QFA Nothing is foolproof to a sufficiently talented fool.
ranger Posted June 15, 2006 Posted June 15, 2006 Not going to give away the sacred 5 digit no for line test then Mark?? I thought it was common knowledge! It is! Isnt it? Most people know the simple number to get the exchange test Ranger The above is my personal opinion and not that of my employer or anyone else.
Monteey Posted June 15, 2006 Posted June 15, 2006 Yeah 17070 but dunno if that works on Kingston stuff dont even know it 1470 will work either, you still have to use 1470 on 17070 on numbers that are automatically withheld Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
Smart Electrics Posted June 16, 2006 Posted June 16, 2006 The number you require is an 0845 number I will dig it out when i get the chance. Marky have a look on infome. there are a couple of numbers. with these you can test any line.
Monteey Posted June 16, 2006 Posted June 16, 2006 Oh yes i know the number to test lines from me mobile but not giving that out here, is there some other fun functions i dont know about Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
norman Posted June 16, 2006 Posted June 16, 2006 Oh yes i know the number to test lines from me mobile but not giving that out here,How about in trade? Nothing is foolproof to a sufficiently talented fool.
