Service Engineer Posted April 25, 2003 Posted April 25, 2003 Does anyone know of an easy way to create a file listing Database. I somehow need to catalogue all the files in the manual listings. ........................................................ Dave Partridge (Romec Service Engineer)
Service Engineer Posted July 12, 2003 Author Posted July 12, 2003 No mate I havn`t Any suggestions ........................................................ Dave Partridge (Romec Service Engineer)
Guest dale Posted July 12, 2003 Posted July 12, 2003 Is the file listing database going to be web based? If so then use MYSQL and PHP to build it, in much the same way that the forum is built.
Service Engineer Posted July 12, 2003 Author Posted July 12, 2003 Im no where near clever enough to do this Dale. So do you know to any other way of doing this ? ........................................................ Dave Partridge (Romec Service Engineer)
Guest dale Posted July 12, 2003 Posted July 12, 2003 Not really if its going to be web based, unless you created it in MS Access then uploaded that to the site but then you need to work out how to get the file open - which is fairly difficult. I can almost guarantee that this website runs on a MYSQL database so why not just set up another table in the database (you will probably have a utility to do this for you called MyPHPAdmin) then tell the web pages to call the data in that table (theres loads of info on this on the web). Or if you are really stuck I will help you do it.
Guest THOMSONSECURITY Posted July 13, 2003 Posted July 13, 2003 Not really if its going to be web based, unless you created it in MS Access then uploaded that to the site but then you need to work out how to get the file open - which is fairly difficult.I can almost guarantee that this website runs on a MYSQL database so why not just set up another table in the database (you will probably have a utility to do this for you called MyPHPAdmin) then tell the web pages to call the data in that table (theres loads of info on this on the web). Or if you are really stuck I will help you do it. Was that the simple way
Guest dale Posted July 13, 2003 Posted July 13, 2003 believe it or not... its fairly easy once youve got your head around some of the basics. PHP is one of the easiest programming languages i have come accross, as you can canabalise other peoples work and get away with it. Many of the websites I write nowadays have PHP in em somewhere.
