Guest Chuck Marlow Posted June 17, 2006 Share Posted June 17, 2006 I have a speed dome that has video, 24vac power, and shows a steady yellow light on the I/O board indicating good Manchester communication. However, I have no control from the head end. I believe that the addressing is correct, (according to tech support). The address is "camera 6" Does anyone have any ideas? I'm at my wits end with this one. I have swapped locations with this cam and it works fine. I did hear from one source that the sheild wire needs to be landed at both ends of the cable to work with Manchester format, however, the installation manual does not show this connection. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11002-sensormatic-speeddome-ultra-iii/ Share on other sites More sharing options...
ian.cant Posted June 18, 2006 Share Posted June 18, 2006 I recall something about not using shielded cable for telemetry on Sensormatic domes. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11002-sensormatic-speeddome-ultra-iii/#findComment-103470 Share on other sites More sharing options...
Guest Posted June 18, 2006 Share Posted June 18, 2006 if you earth both ends any interference has nowhere to go...... ?!? earthing current will just cause humm in that case Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11002-sensormatic-speeddome-ultra-iii/#findComment-103577 Share on other sites More sharing options...
electrocam Posted June 18, 2006 Share Posted June 18, 2006 Set the domes address to 9-0-1 and power it up, this'll put the camera into diagnostic mode where only the camera block will be powered up (not the pan/tilt)- you can then send a command when it says "checking network type" and it'll tell you what protocol was detected. HTH -Dave Trade Access/CCTV Member Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11002-sensormatic-speeddome-ultra-iii/#findComment-103580 Share on other sites More sharing options...
Guest Posted June 18, 2006 Share Posted June 18, 2006 so manchester format is a hum format is it... well, actually it is.. up'n down all the time and fast.. remember,the british earth is like no other..it works.. ground level may vary (and a lot if you didn't know).. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11002-sensormatic-speeddome-ultra-iii/#findComment-103605 Share on other sites More sharing options...
Matt the Teckie Posted June 26, 2006 Share Posted June 26, 2006 Hi Chuck, I don't believe I missed this thread... (big fan of the UltraDome). It might help to have a look at a previous thread posted 24th May by Karab95. What are you controlling your dome with? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11002-sensormatic-speeddome-ultra-iii/#findComment-104797 Share on other sites More sharing options...
