June 17, 200620 yr comment_103443 Went to look at a fault on a panel today, installation nothing to do with me, hadn't met the customer before. Turns out it wasn Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11003-ade-pannel-code/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 17, 200620 yr comment_103446 You must have read this several times before at least? If not, it's been asked numerous times. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11003-ade-pannel-code/#findComment-103446 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 17, 200620 yr comment_103447 Is there any way I can set this back to default and enter a new user code, that is if the engineer code isn't locked out... yes its very to simple do....... do you really need to take two visits to do this & who's paying?? The panel is an ADE unit, installed around 8 years ago. there many different ade models, but remember that different pcb versions of the same model default in different ways Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11003-ade-pannel-code/#findComment-103447 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 18, 200619 yr comment_103494 yes its very to simple do....... do you really need to take two visits to do this & who's paying??there many different ade models, but remember that different pcb versions of the same model default in different ways if its an original optima or concept with the flush keypad membrane, you should be able to guess the code off the busted buttons Watchdog Security (Manchester) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11003-ade-pannel-code/#findComment-103494 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 18, 200619 yr comment_103495 if its an original optima or concept with the flush keypad membrane, you should be able to guess the code off the busted buttons Or default it in 10seconds. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11003-ade-pannel-code/#findComment-103495 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 18, 200619 yr comment_103497 Or default it in 10seconds. That offcut is your best freind....... Watchdog Security (Manchester) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11003-ade-pannel-code/#findComment-103497 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
June 18, 200619 yr comment_103532 That offcut is your best freind....... Not got a clue, could somebody please explain. Google is my friend. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11003-ade-pannel-code/#findComment-103532 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
