Guest steve moore Posted January 13, 2004 Posted January 13, 2004 Are there any companies out there who will take over the maintenance of an //.National Installer.// Galaxy 8 alarm system. The alarm is owned by myself but I am fed up of being ripped off by //.National Installer.//. I live in the Runcorn area, Cheshire. Thanks in advance. Steve Moore
morph Posted January 13, 2004 Posted January 13, 2004 Any local company will be able to look after the system maintenance, however if it it has a police responce then it may have to be upgraded to meet the current ACPO/industry requirements for monitored systems, depending on when it was fitted. The system will have to be reprogrammed in any case- although this is very easy for any alarm engineer to do Best advice is to have look when you are out in your local and choose three comapnies that have a lot of bell boxes up in the area and give them a call. If you only want it as a bells only/ keyholder responce only then you shouldn't have to upgrade it. Colin.
