How Do I Work Out Volts Drop
It is the resistance of a pair that will give you the voltage drop.
no a single core give the same results using my method
compare the tables 100ma over 100M (7 / 0.2) there within a few % of each other
Your paired method must work by having twice the resistance but half the cable length?
Whether we would get the same results through out the table?? Don
System Q Ltd.
0,00178 * 1000 / ( 0,25 x 0,25 x pi ) = 9,065 ohms ( ! one core - end to end ! )
0,535 ohm difference most propably is caused by meter leads and two contact surfaces and meter inaccuracy..
edit: plus i expected CQR to be 0,5mm core diameter
and i seem to have decimal mistake somewhere - which propably is in copper resistance per metre @ 1mm2...
2LRI = Volt Drop
Where:
L is the length of cable in meters
R is the resistance per meter of the cable (see table above) in ohms
I is the maximum current in Amps
(Rcore) x (l x 2) x I
where:
Rcore = resistivity of the cable per one metre
l = length of the cable
2 = 2
I = current ( U/R ) or (V/R there at the island)
i notice some similarities...
drop = A x cable lenght x 0.08 x 2
but only now i got this.. was wondering for a long time from where did you get that 0.08 and A (was expecting I for amperes..)
