Guest Teresa Posted June 20, 2006 Share Posted June 20, 2006 My alarm has suddenley started going off for no reason. I have checked for inscects etc. What could be causing this? Link to comment Share on other sites More sharing options...
Guest Posted June 20, 2006 Share Posted June 20, 2006 quick guess is that it hasn't been serviced for more than 5 years.. Link to comment Share on other sites More sharing options...
Guest Teresa Posted June 20, 2006 Share Posted June 20, 2006 quick guess is that it hasn't been serviced for more than 5 years.. We only moved in last aug so I do not know when it was serviced.Anyone know the cost of servicing and who I should contact? Link to comment Share on other sites More sharing options...
Guest Teresa Posted June 20, 2006 Share Posted June 20, 2006 Barry just outside Cardiff South Wales Link to comment Share on other sites More sharing options...
Deltaseven Posted June 20, 2006 Share Posted June 20, 2006 Is it going off when it is set or unset (or both). What lights show on the display before you put your code in to silence it? Link to comment Share on other sites More sharing options...
Guest Posted June 20, 2006 Share Posted June 20, 2006 Is it going off when it is set or unset (or both). What lights show on the display before you put your code in to silence it? why to bother? it is old battery and needs change plus all the necessary tests, etc.. i'll not have beer for a week if not.. Link to comment Share on other sites More sharing options...
norman Posted June 20, 2006 Share Posted June 20, 2006 Hello Teresa, have a look here and get the system checked and serviced for peace of mind. Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
Guest Teresa Posted June 20, 2006 Share Posted June 20, 2006 It is going off when it is switched to on. I didn't notice the lights as I was in a rush to switch it off. last night it went off 20 minutes after switching it on. I think I'll get it serviced. Thanks teresa Link to comment Share on other sites More sharing options...
Deltaseven Posted June 20, 2006 Share Posted June 20, 2006 why to bother?it is old battery and needs change plus all the necessary tests, etc.. i'll not have beer for a week if not.. You wouldn't ask these questions when you ot to site then? I would. This would indicate whether its likely to be a tamper or detection fault. If Teresa is able to answer this question for the engineer on site, it may save him some time. Knowing that he may ask the question, Teresa may be in a better position to answer. D7 Link to comment Share on other sites More sharing options...
Guest Posted June 20, 2006 Share Posted June 20, 2006 You wouldn't ask these questions when you ot to site then? I would. This would indicate whether its likely to be a tamper or detection fault. If Teresa is able to answer this question for the engineer on site, it may save him some time. Knowing that he may ask the question, Teresa may be in a better position to answer.D7 :yes: Link to comment Share on other sites More sharing options...
