Output Timers
The Comet
Hey there,
Can anyone tell me which programming option to utilise to create an output which when activated is on for a set amount of time and then stops, regardless of if the alarm hasnt been deactivated yet. Although it would need to stop if the alarm was unset.
EG. - Say the trigger is a PA button, it triggers the output, the output remains active for say 2 minutes and then stops, even if the alarm hasnt been stopped yet. But if it was to be activated and then unset then it would stop.
I believe it may be possible with the links function?
cheers
Hey there,
cheers
isn't it possible just to program it otherwise normally but just put a timer on it..?
The timer function is for seperate outputs at certain days and times, not for activations, right?
How do you mean mate?
You set the output as pulse, and set the amount of seconds it stays active for, i think there is a maximum of the top of my head.....
Watchdog Security (Manchester)
no idea since i've seen a galaxy only in the pic's but just trying to give you possible tips to find the way..
