Guest aamir Posted April 27, 2003 Posted April 27, 2003 Hi folks Wonder if someone can help. I've got a A1 AJ600 which apperas to be an omnicrom 7000 with an omnicrom 6000 circuit. I've fitted it and have followed the appropriate installation instructions (very kindly sent to me by thesecurityinstaller) but can't seem to get it working I have all the zones closed off with a loop including the 24hr and PA. But whatever I do on the keypad the 24hr light always is on and consequiently I can't do any programming or tests The internal tamper switch may not be working I suspect since when I take to cover off it doesn't do anything. I can't reset the alarm. I can't get any response out of the tamper switch even when I fiddle with it. Security -ise, its only alarming my workshop and not the house. Any ideas?
dinefwr Posted April 27, 2003 Posted April 27, 2003 Make sure you've put a link for the SCB as this would show a 24 hour light.
