jizzer Posted June 27, 2006 Share Posted June 27, 2006 Hello, Can u fit a 1/3" lens on a 1/2" ccd camera if so what effect will it have ?? Link to comment Share on other sites More sharing options...
Guest Posted June 27, 2006 Share Posted June 27, 2006 yes but the formats wrong, 1/3 being smaller than 1/2 Link to comment Share on other sites More sharing options...
jizzer Posted June 27, 2006 Author Share Posted June 27, 2006 yes but the formats wrong, 1/3 being smaller than 1/2 yes I know but I want to know what the effect would be!!!! I know it will physicaly fit! Link to comment Share on other sites More sharing options...
Guest Posted June 27, 2006 Share Posted June 27, 2006 1/3 being smaller than 1/2 have a guess you plank its too small...... you won't get the full picture Link to comment Share on other sites More sharing options...
jizzer Posted June 27, 2006 Author Share Posted June 27, 2006 have a guess you plank its too small...... you won't get the full picture The Idea of a forum is to share Knowledge if I would have known the answer I WOULD NOT HAVE BOTHERED TO POST THE QUESTION, TAKE YOUR HEAD FROM UP YOUR A@@ If you are not going to give constructive answers do not bother answering questions with sarcasm Link to comment Share on other sites More sharing options...
Guest Posted June 27, 2006 Share Posted June 27, 2006 If you are not going to give constructive answers do not bother answering questions with sarcasm post 2 is the full answer if you don't understand well....... Link to comment Share on other sites More sharing options...
Deltaseven Posted June 27, 2006 Share Posted June 27, 2006 The Idea of a forum is to share Knowledge if I would have known the answer I WOULD NOT HAVE BOTHERED TO POST THE QUESTION, TAKE YOUR HEAD FROM UP YOUR A@@ If you are not going to give constructive answers do not bother answering questions with sarcasm I think it is reasonable to expect a little banter... The tongue-pulling face is an indicator that a tongue-in-cheek comment has just been made. Bit ironic that... Link to comment Share on other sites More sharing options...
Paul Main Posted July 2, 2006 Share Posted July 2, 2006 You will get a "port hole" effect where the image captured by the 1/3 inch lens dosn't cover the whole of the 1/2 inch CCD chip e.g. a black area around the edge of the TV screen. Paul Main ClearView Communications Ltd Robjohns Road Chelmsford Essex CM1 3AG Telephone: 01245 214104 Fax: 01245 214101 paul.main@clearview-communications.com www.clearview-communications.com Link to comment Share on other sites More sharing options...
Guest Cricklewood Electronics Posted July 6, 2006 Share Posted July 6, 2006 You will get a "port hole" effect where the image captured by the 1/3 inch lens dosn't cover the whole of the 1/2 inch CCD chip e.g. a black area around the edge of the TV screen. This is mostly correct but this "Port Hole" effect will only happen if it is a fixed lens eg 4mm. If you are using a varifocal lens then this will not happen all the time, it will only happen when you are using it in it's wider settings. I hope this has helped. Link to comment Share on other sites More sharing options...
