Garage Doors
Guest Onzadog
Guest Onzadog
We all know that up and over doors are pants but what's the best alternative? Sectional or roller? Powered or manual? Which works best with an alarm and which stops the scum getting in with minimal damage?
Security is my primary concern but convenience is my second, I don't want to spend three days unlocking the flippin' thing. I also need access from both sides of the door!
Thanks guys.
Try a roller shutter if its not a very quiet road. But get a steel one and not a plastic one.
Elero do them and have some nice fast motors with remote control.
You can then use a heavy duty contact interface it with a alarm panel and get the best of both worlds.
http://www.elero.com/en;information;for-stockist;d:913.htm
Hope that helps.
Hi Richl, my reasoning for metal was because of the areas i work in, ie London.
For domestic you quite rightly state plastic is fine.
Guest Onzadog
sounds like I'll need to go for a metal one then. I'll be keeping a motorbike and a few mountain bikes behind it, plus it has a door to the house in there. Hence why I want to gte as secure as I can. If I go with a roller, it will hang down 3" or more as there is little clearance, if I go sectional, the track just goes over the door! Can't win!!!
Depends sectional size of small roller shutter is approx 250x250mm
:roflmao Bagdad`s safer :mf_swordfight::plane::turtle: are all here causing all sorts of fun
cheers
