kka Posted June 30, 2006 Posted June 30, 2006 is it possible to send a email directly to a static ip address , if so how?..... thank you Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Gopher Posted June 30, 2006 Posted June 30, 2006 I personally don't think this is possible, the ONLY way I can think of this being possible is if you had some form of mail server (i.e MS Exchange, Mercury Mail) running on a PC connected to that IP, obviously you need to set up at least 1 mailbox on the server and possibly a few more things depending on the software you've used. so instead of user@btinternet.com it would be user@12.34.56.78 which should in "theory" work as long as there is something there waiting for an e-mail to be recieved. Intruder / CCTV / Access Control Technical Support Personal Subscriber to the "K.I.S.S" principle, that's Keep It Simple Stupid, are you?
SystemQ Posted June 30, 2006 Posted June 30, 2006 I guess you are trying to remotely notify someone of an alarm event? For a solution you need to tell everyone what you are trying to achieve with some detail, there are some pretty talented people on the site and someone will have a solution. Paul. System Q Ltd.
amateurandy Posted June 30, 2006 Posted June 30, 2006 I personally don't think this is possible, the ONLY way I can think of this being possible is if you had some form of mail server (i.e MS Exchange, Mercury Mail) running on a PC connected to that IP, obviously you need to set up at least 1 mailbox on the server and possibly a few more things depending on the software you've used. so instead of user@btinternet.com it would be user@12.34.56.78 which should in "theory" work as long as there is something there waiting for an e-mail to be recieved. You would need a mail server, and your MX records setting up in DNS. Not for the IT illiterate! :'(
Gopher Posted June 30, 2006 Posted June 30, 2006 You would need a mail server, and your MX records setting up in DNS.Not for the IT illiterate! :'( Oh Yeah forgot about small Factoid - although it can be done easy with sevices from places like dyndns.org, no-ip.com etc.. I personally have a dyndns account need to set up my mercury mail server and give my theory a test.. Actually i think I need to upgrade my version of Xampp that Im running but I attempted to do it before and well erm they'd changed the format of a file and well i just couldn't get me head around it so I left it well alone... Intruder / CCTV / Access Control Technical Support Personal Subscriber to the "K.I.S.S" principle, that's Keep It Simple Stupid, are you?
Guest Posted July 1, 2006 Posted July 1, 2006 is it possible to send a email directly to a static ip address , if so how?..... thank you only a guess but is this connected to your previous question regarding ip addresses..? regardless that - what are you going to achieve? what is the purpose?
