Guest mersey Posted July 3, 2006 Posted July 3, 2006 can anyone help I have installed a scantronis 9651 panel and have a Nova Gard box outside the problem is that teh connections on the two do not match and I dont know if I have wired it up right The SAB connections are - + Bell swith+ tamper Ret bell switch - tamper feed Strobe - Strobe + the 9651 connections are op1 op2 op3 tr + ls 12v aux 12v aux ov ov Thanks Mersey
antinode Posted July 3, 2006 Posted July 3, 2006 The SAB connections are - Connect this to 0V in the panel + Connect this to 12v AUX in the panel and link to Strobe + in the bell Bell swith+ Ignore this terminal tamper Ret Connect to TR in panel bell switch - Connect to OP1 in panel and program as Bell tamper feed Link to - in the bell Strobe - Connect to OP2 in panel and program as Strobe Strobe + As for "+", link this terminal to + in the bell Trade Member
breff Posted July 3, 2006 Posted July 3, 2006 Spot on Antinode except when we used to fit Novaguards we used to connect 0v to Tamper return, link Tamper Feed to bell -, and wire bell - to TR in the panel. the reasoning behind this was so that the bell would also self activate if the lid was removed as the 0v was removed from it. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
antinode Posted July 3, 2006 Posted July 3, 2006 Thanks for the insight Breff! I'll have a go with that, although it's not been much of a problem for me as all the panels I've fitted have had a bell ring on tamper facility. Not sure if the 9651 does? Trade Member
