Guest Allistair Posted January 17, 2004 Posted January 17, 2004 I have an old Bently Symphony Four alarm panel, and as I am about to move house I need to repair it. I recently put a new battery in it as the old one did not keep its charge, however, the keypads no longer work, (three in all) as the entrance key pad is quite large and flush, (7" wide by 4 3/8" high) I would sooner repair it than replace the panel. can anyone give me guidance on the possible problem please. Or suggest a system with an equivelent keypad for flush mounting of the above size (not the main panel) Thanks Allistair
morph Posted January 17, 2004 Posted January 17, 2004 Give Bentley a ring on Monday Tel: 0161-620-6992. They will sort you out with a user manual and any spare parts you may need. Colin.
