toenee Posted July 5, 2006 Posted July 5, 2006 Hi my previouse post on door contacts got no replys so can I ask what make of grade 3 door contacts do you fit thanks Toenee
j.paul Posted July 5, 2006 Posted July 5, 2006 Hi my previouse post on door contacts got no replys so can I ask what make of grade 3 door contacts do you fit thanks Toenee The new standard for contacts is not out to (I think) October But if you want to start using them, then try the Elmdene ones There are no stupid questions, but there are a LOT of inquisitive idiots.
toenee Posted July 5, 2006 Author Posted July 5, 2006 The new standard for contacts is not out to (I think) October But if you want to start using them, then try the Elmdene ones Thanks jp so what do you fit for grade 3 system I have a system to do and are fitting surface tampered contacts which say they will comply with grade 3 systems if its not standard till october how can an insurance company ask for a grade 3 sytem? I worry about these things and Im just a grunt
Guest rjbsec Posted July 5, 2006 Posted July 5, 2006 Thanks jp so what do you fit for grade 3 system I have a system to do and are fitting surface tampered contacts which say they will comply with grade 3 systems if its not standard till october how can an insurance company ask for a grade 3 sytem? I worry about these things and Im just a grunt Some useful guidance here http://www.ssaib.org/PDFs/Bulletin%201003%...%20guidance.pdf
j.paul Posted July 5, 2006 Posted July 5, 2006 Thanks jp so what do you fit for grade 3 system I have a system to do and are fitting surface tampered contacts which say they will comply with grade 3 systems if its not standard till october how can an insurance company ask for a grade 3 sytem? I worry about these things and Im just a grunt You don't have to fit grade 3 contact till Oct, but the rest of the system has to be grade 3 But we use the Elmdene ones anyway There are no stupid questions, but there are a LOT of inquisitive idiots.
toenee Posted July 6, 2006 Author Posted July 6, 2006 You don't have to fit grade 3 contact till Oct, but the rest of the system has to be grade 3 But we use the Elmdene ones anyway Thanks everyone all the info I need
