Bell Box Question
dommer
I have a DIY alarm with an old bell box. It has no backup batteries inside, and I want to change it for one that does. My question is I live in an area that has a fair amount of power cuts. Will these set the bell off ? I don't want to upset the neighbours. Also after it is installed do they all generally have a feature that allows them to be switched off from inside the house if I need to open the panel for any reason ?
cheers, Dom.
Hello, The power cuts should not set the bell off. What will set the bell off in a power cut is if the backup battery in the panel goes dead.
Not sure what you mean by this
cheers, Dom.
When you enter engineering mode in the panel it will not set the bell off.
djrock
