marksandsparks Posted July 11, 2006 Posted July 11, 2006 I've tried to make sense of previous posts but need an answer more directly to this question please. I know that alarm cable for PIR's shouldn't be run near mains cable. But does this also apply to the alarm cable for my magnetic contacts, keypads, external sounder and communicator? If so I've dropped a clanger.
morph Posted July 11, 2006 Posted July 11, 2006 Yes. You should keep all cabling away from mains cables. Minimum distance 30cm.
Guest Posted July 11, 2006 Posted July 11, 2006 Yes. You should keep all cabling away from mains cables. Minimum distance 30cm. Well, not all cabling, just low voltage. Alarm, data, telephones, TV\satellite, doorbell etc.... And it's 300mm, not 30cm.
Guest Posted July 11, 2006 Posted July 11, 2006 Well, not all cabling, just low voltage. Alarm, data, telephones, TV\satellite, doorbell etc.... And it's 300mm, not 30cm. Or 11.82 inches
Guest Posted July 11, 2006 Posted July 11, 2006 ...And it's 300mm, not 30cm. 0.984 251 969 foot then.. Or 11.82 inches is UK inch different from US ?!?
Guest Posted July 11, 2006 Posted July 11, 2006 0.984 251 969 foot then.. is UK inch different from US ?!? http://www.onlineconversion.com/length_common.htm I know you gallon is, and the beers so weak i thought i was drinking water
Guest Posted July 11, 2006 Posted July 11, 2006 http://www.onlineconversion.com/length_common.htm 300 millimeter = 11.811 023 622 inch [international, U.S.] I know you gallon is, and the beers so weak i thought i was drinking water i didn't know we used gallon here in coldshire but beer is lame in sweden - not here
Guest Posted July 11, 2006 Posted July 11, 2006 Teach me to look more closely, Welcome Finland. Ei vaihde sinun laulelma ulostaa Hope thats what i think it says
secboy Posted July 11, 2006 Posted July 11, 2006 Well, not all cabling, just low voltage. Alarm, data, telephones, TV\satellite, doorbell etc.... And it's 300mm, not 30cm. If this is correct then segregated/partioned distribution plastic trunking as used round offices etc cannot comply!!! ?????
