Guest Box Posted January 17, 2004 Share Posted January 17, 2004 I have moved into a new house with an accenta 8 alarm panel, i do not know the engineer code and want to set zone 8 to fire, a engineer manual i down loaded says i need the engieers code to do this, so i need to know how to "Crash" or "hard re set" the system to fatory settings. Thanks Chris Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1131-crash-reset/ Share on other sites More sharing options...
Guest Posted January 17, 2004 Share Posted January 17, 2004 are there any jumpers inside the main pannel or tempary reset link outs ????? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1131-crash-reset/#findComment-6089 Share on other sites More sharing options...
Guest Box Posted January 17, 2004 Share Posted January 17, 2004 I Dont Think so, how will that help to reset it? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1131-crash-reset/#findComment-6090 Share on other sites More sharing options...
Guest Posted January 17, 2004 Share Posted January 17, 2004 on some panels if you cross the reset jumpers they reset the codes to factory reset for a short time enableing you to put the default eng code in and change it Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1131-crash-reset/#findComment-6092 Share on other sites More sharing options...
Guest Box Posted January 17, 2004 Share Posted January 17, 2004 how will know whick jumpers are the correct ones to cross, i need a manual, to find out how to change the engineer code if that works too. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1131-crash-reset/#findComment-6093 Share on other sites More sharing options...
Guest Posted January 17, 2004 Share Posted January 17, 2004 is the panel led or lcd display if led i'am stuck too but if lcd it should be under change access/user codes then scroll through to eng code put manufacturers default in then new code i think, but ive not been in the game long so dont quote me Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1131-crash-reset/#findComment-6096 Share on other sites More sharing options...
Guest pto Posted January 17, 2004 Share Posted January 17, 2004 9+19 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1131-crash-reset/#findComment-6097 Share on other sites More sharing options...
Guest Box Posted January 17, 2004 Share Posted January 17, 2004 its an LED one, Thanks anyway, TO PTO: ?? 9+19??? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1131-crash-reset/#findComment-6098 Share on other sites More sharing options...
Guest Posted January 17, 2004 Share Posted January 17, 2004 9 + 19 must be the jumpers to cross i beleive but i'm not sure its the only thing i can think of if your still in here i'am popping to the chat room Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1131-crash-reset/#findComment-6099 Share on other sites More sharing options...
Service Engineer Posted January 17, 2004 Share Posted January 17, 2004 It gives you all the info you need in the Engineer Manual. ........................................................ Dave Partridge (Romec Service Engineer) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1131-crash-reset/#findComment-6100 Share on other sites More sharing options...
