Veritas 8c Problems
Guest pandagirl
Guest pandagirl
that code doesn't work, the only code that works is 1234 its the old type alarm (1997)
Back to square one then , you have no user code , so you need your panel defaulting back to factory presets , then 4321 will be your user code.It will then require reprogramming to suit.
Guest pandagirl
well how do i go about doing that then, i had the engineer out twice. the 1st time the disconnected the battery and said it was defulted back to factory settings. do i need to call out another engineer??
  • 1 month later...
Hello
Can anyone help me, I haved moved into a house with a veritas 8c alarm, with no setting instructions. I have a code, but no way of how too use it.
Can someone help or direct me to where I can get some
Thanks
Martiin Cox
Hello
Thanks
Martiin Cox
Veritas 8C user manual Veritas8c.pdf
Hope this helps, we can't give you engineer manuals or info though sorry.
