Guest Kinclad Posted July 18, 2006 Posted July 18, 2006 Hi All, Apologies in advance if this question has been asked before. I have a Vertias alarm, I don
FASTCAR Posted July 18, 2006 Posted July 18, 2006 Your control panel has crashed , the battery is most probably goosed , as it should have kept your system up and running for 6 - 8 hours in the event of a power cut. You will require an engineer to revive it , battery test etc. If you post your location , there may be someone from the forum who can help you out. Regards,
