dommer Posted July 18, 2006 Posted July 18, 2006 Hi. Hoping for some advice. I have an old alarm system that was not working when I moved in. I have got it working now, and I am gradually updating the kit, PIR's Panel and Bell Box. Only DIY stuff but it will work fine for me. Currently I have a Bell outside, yes a bell, a dinging bell. I want to replace this as it has not battery backup. I was thinking of buying a Reson8 Bell Box, I have an ADE panel. My questions are - 1) Any advice on which end to connect first, panel first or Bell ? 2) How long will it sound when fitting, and what connection makes it stop ? 3) Currently if the Bell goes off by mistake, I can cut the power or remove a Bell wire from the panel. If it has is own batteries, is there a way of stopping it instantly ? I wouldn't want to wait 20 mins before it reset itself. Any advice would be great. Thanks, Dom.
antinode Posted July 18, 2006 Posted July 18, 2006 Firstly, I would look somewhere else for a bell box. It was probably called the Reason 8 because there are 8 reasons as to why you should'nt buy one. I usually connect the bell box first and get it into standby mode (ie silenced but running off it's own battery) then connect the panel end without shorting any wires together. I would recommend you connect the panel end first with the control panel switched OFF, then the bell, then switch the panel on. There should be a test function on the Reason 8 so it will only sound for a few seconds whilst in that mode. The manual will detail this feature. If the bell is installed properly, there should NOT be a way of stopping it if it looses it's hold off voltage short of re-applying this voltage. If the installation is to a good standard and the equipment is good quality, there is no reason to worry about this happening. Trade Member
dommer Posted July 18, 2006 Author Posted July 18, 2006 Thanks, what bell box would you recommend for a DIY'er ? Reson8 Bell Box is only
antinode Posted July 18, 2006 Posted July 18, 2006 I really like the Novagards, but you won't be able to get hold of them easily. The Pyronix Belle is reliable enough and loud too although it might be a little fiddly to install. You can get hold of them on the internet easily. Or Texecom, as Adi said above. Trade Member
dommer Posted July 18, 2006 Author Posted July 18, 2006 I really like the Novagards, but you won't be able to get hold of them easily. The Pyronix Belle is reliable enough and loud too although it might be a little fiddly to install. You can get hold of them on the internet easily.Or Texecom, as Adi said above. Pyronix Belle a bit pricey for me, is this better ? http://www.alertelectrical.com/product.asp?prodID=43 Sorry forgot to ask, which is the best Dual PIR to buy from Alert Electrical ? It will save on postage to order at the same time. Ps thanks for the replies I will happilly listen to the experts, I was all set to get the Reason 8. , Dom.
Adi Posted July 18, 2006 Posted July 18, 2006 Id go texecom. but they all decent. others on here would probably say rokonet. for a domestic i would probably advise against pyronix to big and ugly. I really can't be ar**** with it anymore.
dommer Posted July 18, 2006 Author Posted July 18, 2006 Hi, I got Texecom for the Bell Box and Dual PIR, thanks for your help everyone.
