Guest Az234 Posted July 19, 2006 Posted July 19, 2006 Hi, I have a gardtec 593 and a sd1+. When the alarm is set at night and i come down in the morning it gives me no warning and goes off the installer never told me how to set it for night time and its annoying wakeing the whole village when i wake up.. also when i omit a zone and then click set again it says all zones on when setting. One more thing how do i set it so i can just enter a code for night time rather than keep omiting zones. if anyone can help i will be very happy Thanks Az
Guest RICHL Posted July 19, 2006 Posted July 19, 2006 Try part setting ie code + 1,2 or 3 rather than full set for a night time. If that doesnt work then you will need to contact the installer and get him to fix the programming as it is a rather obvious oversight.
Smart Electrics Posted July 19, 2006 Posted July 19, 2006 Pressing YES< YES twice then your code or presenting your prox to the reader will do the same for part setting 1. If that does not work then the zones in question have not been programed for part setting and will need your installer or an engineer to set these up.
