Guest jonhunt2000 Posted July 19, 2006 Posted July 19, 2006 I have a fault on my Securit 700L The '1' led stay on when I try to set the alarm, and the alarm will not set. I suspect that it is the sensor, but I don't know which sensor number 1 is ? so I have a number of questions 1. Can I set the alarm without setting the 1 area, I have tried to do this using the 'manual isolation settings', but it does not let me isolate this area. Is there any way I can disabale the sensor, I can do without it for now as long as I can set the alarm. 2. How can I find out which sensor is faulty - I have tried the walk test, but it just lights up led 1 all the time. 3. Is it liklely that I need to clean the sensor out i.e. dust or does it need a new one, can I fix a new one. I am competent in IT, electronics electical, I just need someone to advise me what to do. Thanks for the great site
FASTCAR Posted July 19, 2006 Posted July 19, 2006 Hi , Its most probably your front door contact. IIRC zone 1 is fixed exit / entry , and non ommitable. Regards.
Guest jonhunt2000 Posted July 19, 2006 Posted July 19, 2006 aaaah yes I had forgotton about that. Is it likely to be faulty - can I do anything to diagnose whats wrong, or should I just replace it thanks for your quick reply -
FASTCAR Posted July 19, 2006 Posted July 19, 2006 Make sure both parts are still there...(magnet and reed switch).If confident , remove the switch and check that the wires are still attached under the 2 silver screws. Rgs
Guest jonhunt2000 Posted July 21, 2006 Posted July 21, 2006 I replaced both magent and reed switch, and workd perfect now Thanks very much for your help
