Davey Posted July 21, 2006 Share Posted July 21, 2006 I have aquired an ACE unit. It has only come with installation instructions for a Gardtec 800/69x Series. How do I install this onto a 370 panel ? I only have 1 RKP which has the eol jumper on. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11407-gardtec-ace/ Share on other sites More sharing options...
arfur mo Posted July 21, 2006 Share Posted July 21, 2006 I have aquired an ACE unit. It has only come with installation instructions for a Gardtec 800/69x Series.How do I install this onto a 370 panel ? I only have 1 RKP which has the eol jumper on. hi davey, you need an ACE receiver to go with it, this is a small unit with 3 buttons on it and wires in like a keypad. not sure if still available as we have moved on to prox and radio but i have a few in stock, i could be bribed to part with one but you need an engineer to fit it - beleive me! the 370's were not issued with an ACE enable keypad, unlike the bigger G8-- and G5-- ranges still you can use the fob - to keep the door open in this heat regs alan If you think education is difficult, try being stupid!!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11407-gardtec-ace/#findComment-107751 Share on other sites More sharing options...
Davey Posted July 21, 2006 Author Share Posted July 21, 2006 hi davey,you need an ACE receiver to go with it, this is a small unit with 3 buttons on it and wires in like a keypad. not sure if still available as we have moved on to prox and radio but i have a few in stock, i could be bribed to part with one but you need an engineer to fit it - beleive me! the 370's were not issued with an ACE enable keypad, unlike the bigger G8-- and G5-- ranges still you can use the fob - to keep the door open in this heat regs alan Its the receiver that I have, just it only has instructions for the 800/59x series and im not sure how to connect it with my existing 580 LED RKP. Internally it has 5 sets of jumpers but jumpers 3 (PN) & 5 (EOL) have no pins. I havn't aquired any keyfob's yet - any suggestions where to get them other than RS Regards Dave Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11407-gardtec-ace/#findComment-107757 Share on other sites More sharing options...
Paul P Posted July 21, 2006 Share Posted July 21, 2006 Its the receiver that I have, just it only has instructions for the 800/59x series and im not sure how to connect it with my existing 580 LED RKP.Internally it has 5 sets of jumpers but jumpers 3 (PN) & 5 (EOL) have no pins. I havn't aquired any keyfob's yet - any suggestions where to get them other than RS Regards Dave The newer receivers are made either for the 370/580/581 or 593/595/800 series they are not interchangeable. Trade Member Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11407-gardtec-ace/#findComment-107765 Share on other sites More sharing options...
arfur mo Posted July 21, 2006 Share Posted July 21, 2006 The newer receivers are made either for the 370/580/581 or 593/595/800 series they are not interchangeable. hi paul, are you sure, on the one's i have there is a link to change from one series to another, (default setting is g8 series) but i have had them for a while as its better to use prox. regs alan If you think education is difficult, try being stupid!!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11407-gardtec-ace/#findComment-107784 Share on other sites More sharing options...
Paul P Posted July 22, 2006 Share Posted July 22, 2006 hi paul, are you sure, on the one's i have there is a link to change from one series to another, (default setting is g8 series) but i have had them for a while as its better to use prox.regs alan Extract from catalogue attached. Gardtec_Ace.pdf Trade Member Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11407-gardtec-ace/#findComment-107803 Share on other sites More sharing options...
arfur mo Posted July 22, 2006 Share Posted July 22, 2006 Extract from catalogue attached. Gardtec_Ace.pdf hi paul, you might br right mate, piccy do not show a g370 option, i'll dig mine out and have a look - been about 2 years sinc i used this receiver, but thinkig about i only used about 3 x 370's just did not like the programming to much . regs alan If you think education is difficult, try being stupid!!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/11407-gardtec-ace/#findComment-107825 Share on other sites More sharing options...
