Guest terrylidd Posted January 18, 2004 Posted January 18, 2004 I have an accord xpc and wish to put it to use. I have worked out most wiring how ever not the PIRs. how do i connect the wires within the PIR. do I need to use a 1K and if where do I place it? Please help and thank you in advance
morph Posted January 19, 2004 Posted January 19, 2004 Have a look at this wiring diagram it is fairly straight forward. XPC Wiring You have a choice of wiring, but if you have never done it before I would go for the double pole wiring and remember till you choose the wiring type in the program you will have a fault showing. Colin.
