Guest gdraper Posted July 23, 2006 Posted July 23, 2006 I have an Optima G3 which I installed and has ben fine till lately. All Ok and when the alarm is 'UNSET' seems to go into a chime mode on channel 2. I have the test instructions and when I go into ALAM TEST mose I expect the DAY amnd TAMPER lights but only get TAMPER If I do POWER UP RESET it seems to clear but has happened twice now I bow to the experts - any ideas or is it a new box soon Many thanks Graeme
morph Posted July 23, 2006 Posted July 23, 2006 Switch the chime off. Do you have the correct instructions? did you get them of the installer or off the www.
Guest gdraper Posted July 26, 2006 Posted July 26, 2006 alarmgard said: Switch the chime off.Do you have the correct instructions? did you get them of the installer or off the www. Got them from www MAYCO said: follow these steps:1. have syetem in unset mode 2. press RESET 3. press CHIME 4. ZONE 2 should be iluminated 5. press 2 on the keypad 6. ZONE 2 LED should go out 7. press RESET twice 8. now in UNSETMODE activate ZONE 2, IT SHOULD NOT CHIME. Thank you for taking time to answer this
