Texecom Pirs
tom25
i would expect there is. might be disabled thou.
Hi, does the Texecom Mirage Quad PIR have an LED inside it to indicate activity or walk test?
should light up to show its open if the led's not controlled by the panel
ok thanks, just wondering if i should buy a few and if they would be easy to walk test.
Thanks, will do some more research to make sure
The Mirage does have an LED. The Prestige Quad has three: one for each element and one for alarm.
Trade Member
Thanks
The walk test should be tested and indicated at the panel, just because the led lights up it is not a guarantee that the detector is active :no:
Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
