Do I Need A New Power Supply?
cjd
hi, hope someone can help. I've got a galaxy 60 panel and have currently got 2 keypads on it (bothe the old modern security systems type.) i want to add another RKP but for some unknown reason to me it won't work. The new RKP will flash *'s, but then the other 2 RKP's dont respond to anything i,e, i cant put any codes it etc. I've just upraded from version 1.?? to version 2.10, but it hasnt made any difference. as soon as i connect the new RKP to the power supply the other 2 start bleeping radomly and will not respond - until i disconnect the new one i want to add. I've tried another keypad,but it doesnt do anything. Do i need a new power supply that will allow me to add this RKP, or do i need to alter something on the main PCB? Help would be appreciated.
Thanks
Have you addressed it correctley ?
Is it an old Thorn one?
it's not and old thorn one, i have addressed it correctly changed the selector switch from "0" to "2" as "0" & "1" are the other 2 keypads.
How have you wired it? If it is at the end of the line (connected to the last RKP) you need to put the EOL resistor across A+B of the last RKP. (new one)
There may be a compatibilty issue with the RKP's but I'm not too sure of that.
If you don't know......ask.
from what you have said, i dont think i've done it right. i assume it's supposed to be connected after RKP1, and not as i've done it RKP0 to RKP1 and from RKP 0 to RKP 2. am i correct in assuming that the power from one keypad is OK to be used onto the other, and that i dont have to run separtae wires from the panel to each RKP?
I think you're describing that you have 'starred' off the data line, which is not recommended. The data should be wired in a daisy chain, with the EOL connected to the last in line. You can use the same power supply for all 3 RKP's, depending on the length of the runs.(Volt Drop) If you do need another power supply, you should common the negs.
If I recall correctly Bri you can star off the data line but you must fit a 680 ohm resistor on each keypad that is starred. Like you say though, it's not the best way to do it.
Trade Member
thanks for that, i'll have to do some rewiring then!! is it not acceptable to star out - would it case problems, or does it make things easier if their daisychained
You can star off the line from the panel not a RKP and the 680 resistor should be cut in the panel and one fitted to each RKP, like you say.
Yes, it causes problems like ***** displayed on RKP!
doesn't the resistor size vary according the amount of keypads (if star network)?
:question:
