Odyssey 3 Strobe Problem
the boss
Hi Guys
I fitted an Odyssey 3E Bell box as a second box which is wired as per instruction manual (set with SCB enabled) but i can not get the strobe to flash all I get is a loud knocking noise the !st strobe works fine. Is the bell box US or have I done something wrong?
Hi Guys
Probably your Mrs telling you to give it up and get an engineer in :P
Wire them sepertaly, then see if you have worked out the links if they both work fine.
cheers
PS whats the 1st bell called?
Biatch :P
I knew it as soon as i posted it, your a bright spark tonight...muwhahahahaha
