How To Connect Tate Bell Box
Guest greeny
Guest greeny
Can anyone tell me which connections to use to connect a Tate security T-B600 bell box to a A1 Omnicron 6000 control box.The control box connections use a connection marked
SCB
RT O
connection points, as well as, AUX 24HR, P.A, ZONES 1 2 3 4, SD , SC , KK, SP, BELL+-, STROBE+-
and the bell box connections are
STB HOLD OFF RTN TRG
IF I DISCONNECT THE SCB RT O TERMINAL THE INTERNAL SOUNDER SOUNDS.
PLEASE HELP
Hi
connections as follows.
STB = STROBE -
HOLD = BELL +
OFF = SCB O
RTN = SCB RT
TRG = BELL -
DISCONNECTING SCB TERMINALS WILL TRIGGER A TAMPER FAULT ON YOUR PANEL.
PRESS PROGRAM FUNTION AND YOUR ENG CODE TO ALLOW ACCESS TO THESE CONNECTIONS.
Guest greeny
Hi
STB = STROBE -
HOLD = BELL +
OFF = SCB O
RTN = SCB RT
TRG = BELL -
Thankyou, did what you said and all works great.
Paul
Tie the bell box and the control panel together with a brick and some strong rope and throw them both in the sea :P
waste of good brick :whistle:
