Guest ALSEC Posted July 28, 2006 Posted July 28, 2006 If you're not trade then how did you get hold of that panel?
Guest rjbsec Posted July 28, 2006 Posted July 28, 2006 If you're not trade then how did you get hold of that panel? Ebay? There's been a few.
Guest logical001 Posted July 30, 2006 Posted July 30, 2006 Ebay?There's been a few. You can buy this stuff on Ebay (where I got the panel M800, 2 x Mnodes and 2 keypads for 180 quid new in box). My local dealer supplied the version SD2 dialler unit only. Ebay was very useful, otherwise the whole kit would have been eyewatering. Overkill perhaps for a domestic house but as I had the floor boards up and an electrician working with me, I could route alarm cables (properly seperated from power) and thought I'd get a decent panel to match. I would have called in an alarm company but having seen the work of a few local ones who shall remain nameless, I prefered this. However I will probably get my work checked and the alarm correctly setup by a professional. So if any of you are in the South Birmingham area and like playing with Menvier panels then let me know - Must say it is cracking stuff and very well thought through. Which country does the company / design originate? Many thanks J.
Guest Posted July 30, 2006 Posted July 30, 2006 Overkill perhaps for a domestic house but as I had the floor boards up and an electrician working with me, I could route alarm cables (properly seperated from power) and thought I'd get a decent panel to match. Whever possible the cable goes under the floor I would have called in an alarm company but having seen the work of a few local ones who shall remain nameless, I prefered this Your local branch of secom? An independent nsi / ssaib company? Or cheap and chearful Sh1t Alarms (every towns got at least one) However I will probably get my work checked and the alarm correctly setup by a professional you will find most firm try to say away form this sort of thing Must say it is cracking stuff and very well thought through. Which country does the company / design originate? Most decent controls used in the uk come from the uk in this case as with many others the companies owned by the yanks
