satsuma01 Posted December 3, 2007 Posted December 3, 2007 i have one a pir triggering for no apparent reason, in a lounge of a customers house, nothing distrubed, checked wiring perfect, changed pcb in detector still f/a linked out alarm zone connections on panel no false alarms, bearing mind room is ambient temperature and no-one lives there at moment due to old lady dieing panel is texe r8 with texe detectors any ideas anyone?? p.s detector faces away from window into room "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
Guest anguscanplay Posted December 3, 2007 Posted December 3, 2007 i have one a pir triggering for no apparent reason, in a lounge of a customers house, nothing distrubed, checked wiring perfect, changed pcb in detector still f/a linked out alarm zone connections on panel no false alarms, bearing mind room is ambient temperature and no-one lives there at moment due to old lady dieingpanel is texe r8 with texe detectors any ideas anyone?? p.s detector faces away from window into room this time of year ? - mouse
Tel Posted December 3, 2007 Posted December 3, 2007 i have one a pir triggering for no apparent reason, in a lounge of a customers house, nothing distrubed, checked wiring perfect, changed pcb in detector still f/a linked out alarm zone connections on panel no false alarms, bearing mind room is ambient temperature and no-one lives there at moment due to old lady dieingpanel is texe r8 with texe detectors any ideas anyone?? p.s detector faces away from window into room voltage,vermin, rf, environmental, controls failing, better pir needed ect......
arfur mo Posted December 3, 2007 Posted December 3, 2007 i have one a pir triggering for no apparent reason, in a lounge of a customers house, nothing distrubed, checked wiring perfect, changed pcb in detector still f/a linked out alarm zone connections on panel no false alarms, bearing mind room is ambient temperature and no-one lives there at moment due to old lady dieingpanel is texe r8 with texe detectors any ideas anyone?? p.s detector faces away from window into room you changed the pcb but did you look for any large spiders behind the casing? if you want to prove environmental or system problem then obscure the pir with a thick cardboard box and wait a week, no alarms problem is likely enviorement, obviously inform your client and get it signed for before doing this. as this is the 2nd pcb have you tested the battery properly also the panel voltage on a prolonged mains power down at the aux terminals? is there any sign in the log or a power cut (mains powered clocks on cookers and the like can be a clue) have a real close look at the aux power connections in the panel/psu, make sure all the aux cables are tight and held properly in the connector - oh! and just shoot any cats you see, and if they twitch shoot them again . regs alan If you think education is difficult, try being stupid!!!!
