Alarm Communication Issues
ey, I'm not the one that's been sloping off for the last 3 days after getting an intimate text message. :ninja:
If you don't know......ask.
Ok - Back from the burglary that didn't happen... dammit.
Now telecoms isn't my department - but I'm pretty confident we are using some kind of call routing for cheaper calls. In terms of checking what effect this has - this 'magic number' - is it a prefix that needs to be dialled before the normal number to ensure a BT line call is made?
If so - could someone enlighten me a bit more via the PM system?
I've had all kinds of people looking at this - and if it's something simple - I'm gonna bash their heads together :)
heads together :)
Chris
It is a prefix to ensure that calls use BT, as some of the lines call routing companys use do not transmit the right frequencies and cause faults on digis. Your alarm Co should have checked this out striaght away, but then again the big ones are not always the best.
Bri,
Does that entitle me to another week off :cry:
www.nova-security.co.uk
www.nsiapproved.co.uk
You will need to check with your telecoms people and get your alarm Co to prefix the digis with 1280
But and its a big but, if ever you stop call routing then the digi wont work until the prefix number is removed, best thing woul be having a dedicated line that does not use call routing or upgrade tp dual signalling.
Now i can have another week off.
Chris, how about a Security Installer Discount card for all our members :whistle: , if you dont ask...
I have had this problem before and we found it to be the call routing so we had to prefix with a number but we also found that because all the stores set there alarms at around the same time there was to many signals to the arc so the earlier set stores registered but the ones that was in a queue they didnt register so the arc had to add more lines and we seperated the numbers between the stores....... A bit of a chapter but there you go :whistle:
lee
Lee Sutton
E-Mail: leesutton@centurianfire.co.uk
Website: www.centurianfire.co.uk
Phone: 0845 094 9870
CENTURIAN FIRE & SECURITY (part of centurian group limited)
Do your lines have broadband installed on them and when (if you have one) does your PDQ machine back itself up??....is this on the same line?????
not necessarily because his panels don't show CommFail/FailureToCommunicate error..
... but we also found that because all the stores set there alarms at around the same time there was to many signals to the arc so the earlier set stores registered but the ones that was in a queue they didnt register
absolutely rubbish ARC in this case! they should follow their line traffic themselves!! :ranting:
and absolutely wrong fix to the problem! :banned:
