Guest moylo Posted July 31, 2006 Posted July 31, 2006 Hi folks, Can anyone help me?? I have veritas 8C and the power was cut from it for a few days. When the power has been restored the power lite (the top right hand corner lite) remains flashing and when I try and set the alarm it does not set. Also when I try and set only one of the zone led's flashes making me think that I have lost the other two zones, can anyone help. brianmoylan@btconnect.com
kka Posted July 31, 2006 Posted July 31, 2006 Hi folks,Can anyone help me?? I have veritas 8C and the power was cut from it for a few days. When the power has been restored the power lite (the top right hand corner lite) remains flashing and when I try and set the alarm it does not set. Also when I try and set only one of the zone led's flashes making me think that I have lost the other two zones, can anyone help. brianmoylan@btconnect.com have you checked the fuse in the fused connection unit? it should be 3 amp, make sure it is okay first Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Guest moylo Posted July 31, 2006 Posted July 31, 2006 have you checked the fuse in the fused connection unit? it should be 3 amp, make sure it is okay first Yep fuse ok
kka Posted July 31, 2006 Posted July 31, 2006 Yep fuse ok there are two fuses in that line, the other requires access to the control panel, extreme care should be exercised when opening the panel, due to the dangers of mains electricity. i suggest if you are not sure, then contact a local installer who will be able to help, (chargable sorry) Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
FASTCAR Posted July 31, 2006 Posted July 31, 2006 If your battery is completely flat , the power led will continue to flash , indicating a fault , the light should stop flasking soon. If not , your battery will need checking / replacing. Regards.
Guest moylo Posted July 31, 2006 Posted July 31, 2006 If your battery is completely flat , the power led will continue to flash , indicating a fault , the light should stop flasking soon. If not , your battery will need checking / replacing. Regards. Thnaks folks. Now what about the thing were I am only getting one zone to flash, how do I add the other two zones or can I test them to see if they work
kka Posted July 31, 2006 Posted July 31, 2006 Thnaks folks. Now what about the thing were I am only getting one zone to flash, how do I add the other two zones or can I test them to see if they work fastcar is correct, if you have mains power supplied, and the battery charging circuit is okay, then it will begin to charge the battery and the light will go steady,usually after a short period of time. now please can you tell us a little more about these two zones are they door contacts or pirs or something else moylo, have to go now, but you are in very good hands with these other two engineers, Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Guest moylo Posted July 31, 2006 Posted July 31, 2006 fastcar is correct, if you have mains power supplied, and the battery charging circuit is okay, then it will begin to charge the battery and the light will go steady,usually after a short period of time. now please can you tell us a little more about these two zones are they door contacts or pirs or something else Three pirs in total. When I use to set the alarm the three led's would flash to show that they were on. But now that I try to set the alrm only zone 1 lites up, the other two do not come on, I dont know if I have omitted them when hitting any buttons, how do I include them
