IPAlarms Posted July 31, 2006 Posted July 31, 2006 One of the things I never really got into was audio verification. Are many of you guys using it ? Is it getting more popular - or dying off ? If you are using it now - which manufacturers equipment do you use ? Thanks in Advance. Free Alarm Monitoring over the Internet from IP Alarms
JB_ Posted July 31, 2006 Posted July 31, 2006 AV60 from ICM, only ever used these and they work fairly well. Easy enough to configure once you know what your doing. Don't most people that use Audio verification use these?
Guest ALSEC Posted July 31, 2006 Posted July 31, 2006 Same as above AV60 and also AV panels which have AV boards inside..
avcctv Posted July 31, 2006 Posted July 31, 2006 Ditto, have worked on the AV panels, but also came across a couple of Galaxys with audio verification in some places. Didn't have much to do with the Galaxys so way of working but there was a module inside designed for the purpose. The older I get, the faster I was.
Guest ALSEC Posted July 31, 2006 Posted July 31, 2006 Ditto, have worked on the AV panels, but also came across a couple of Galaxys with audio verification in Jessop stores. Didn't have much to do with the Galaxys so way of working but there was a module inside designed for the purpose. Would love to continue this conversation but it's in a public area..
IPAlarms Posted July 31, 2006 Author Posted July 31, 2006 Thanks Guys. I hadn't heard of the AV60 before, but it seems like good kit. What about the Digicom AV from Sensortech - anyone used that ? Free Alarm Monitoring over the Internet from IP Alarms
whistle Posted July 31, 2006 Posted July 31, 2006 Have used lots of AV60 in my years and found very good. Also lots of 3250 and 4250 while at the hex. Found the best audio stuff i have ever seen.
IPAlarms Posted August 1, 2006 Author Posted August 1, 2006 Also lots of 3250 and 4250 while at the hex. Found the best audio stuff i have ever seen. Who manufactures the 3250 and 4250 ? Free Alarm Monitoring over the Internet from IP Alarms
norman Posted August 1, 2006 Posted August 1, 2006 Advantor Nothing is foolproof to a sufficiently talented fool.
bellman Posted August 1, 2006 Posted August 1, 2006 3250 and 4250 are both manufactured by advantor corp in the states. They were branded and sold as SONITROL here in the uk and the UK franchise was aquired by tyco several years ago. It's a pretty powerfull system the 4250, lots of functionality and all fully programmed and controlled by the ARC The audio from them as whistle states above is exceptional when correctly installed and configured. It uses audio for detection as well as for confirmation, several systems I have serviced only have mic's and a contact on the entry door. I don't think they are certified for the new regs though. Sonitrol's wesite is Here Advantor's website is Here Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
