Dave Walton Posted July 31, 2006 Posted July 31, 2006 After a little help here, my daughter has just moved into her first house which is fitted with a ADTGalaxy control panel,she has the user code from the previous owner so she can set/unset the system,she wants to change the code but cannot because there are no manuals,can any body help.
Guest Posted July 31, 2006 Posted July 31, 2006 Chris Bellman may be able to help if its just for a user code change.
whistle Posted July 31, 2006 Posted July 31, 2006 Do you know the model of the galaxy? look on the main panel there will be a small sticker next to the top screw with the model EG 8, 16+,18 ect
Dave Walton Posted July 31, 2006 Author Posted July 31, 2006 Do you know the model of the galaxy?look on the main panel there will be a small sticker next to the top screw with the model EG 8, 16+,18 ect //.National Installer.// Galaxy 2-12 Version 1
whistle Posted July 31, 2006 Posted July 31, 2006 So its quite a new installation then? is it under contract?
Dave Walton Posted July 31, 2006 Author Posted July 31, 2006 So its quite a new installation then?is it under contract? Dont know how long it has been installed,shes just moved into the house and the system was monitored up utill she moved in but is not at the moment, she just wants to change the user code.
Guest Posted July 31, 2006 Posted July 31, 2006 I think some of the guys might be refering to the fact it may have been on contract as a monitored system. If this was the case when it goes of it needs an engineer reset.
whistle Posted July 31, 2006 Posted July 31, 2006 Also it may not have an external sounder, just a dummy cover
Guest ALSEC Posted August 1, 2006 Posted August 1, 2006 User code ENT Menu 42 ENT Work your way through the menus using the A & B keys (right and left respectively) and the ENT key - this is very simple
