Guest NTS Telecom Posted August 2, 2006 Posted August 2, 2006 Do you have a CS Receiver that you no longer require? Preferably a Scancom 6100. Condition is not important as it is only being used in a test lab that designs PSTN test equipment. Paul Paul at ntstelecom#co#uk 01635 231316 www.ntstelecom.co.uk
IPAlarms Posted August 2, 2006 Posted August 2, 2006 Do you have a CS Receiver that you no longer require? Preferably a Scancom 6100.Condition is not important as it is only being used in a test lab that designs PSTN test equipment. eBay is your friend for this one if you can wait for one to crop up. You could try Jin Rojas from the US if you don't mind paying for international carrier (jrojas@tech-man.com). My suggestion would be to telephone around all the central stations and ask them direct. Try Jonathan at ARC Monitoring - I think he has a couple of old ones lying around. As a last resort and if you only want to see what is coming out of your test equipment, just use some serial sniffing software. There are a few good ones around that give you 30 days free trial. That is what I use when I write receiver interfaces for my software. Hope this helps. Free Alarm Monitoring over the Internet from IP Alarms
