Guest coresec Posted August 2, 2006 Posted August 2, 2006 Hi All! Quick survey: What wifi systems you guys use & recommend. We are definatley getting more requests for wifi systems, we use Galaxy with gal/dominal wifi sensors, good however seems expensive. Thoughts?
morph Posted August 2, 2006 Posted August 2, 2006 You would do well to use the search feature of these forums, been asked about many times. There are lots of good opinions and lots of bad. Rememeber also with most things you get what you pay for.
Guest rjbsec Posted August 2, 2006 Posted August 2, 2006 Thought G2 with Domonial detectors was a well priced option!
Guest Posted August 2, 2006 Posted August 2, 2006 ...There are lots of good opinions and lots of bad. ... indeed!!
dubiousp Posted December 5, 2011 Posted December 5, 2011 Hye Ive installed a couple of the Dominal alrms and seem to have a problem on both. Im using the communicator to essentially dial a normal phone using the voice option. The manual suggest that a series of beeps will be heard then a couple of key strokes can be entered to either silence or reset alarm. Has anybody had any success in doing this
