Scantronic 9600 Control Panel
Guest Peter Deans
Guest Peter Deans
I have recently purchased a house which is fitted with a Scantronic 9600 control panel. My problem is that on occasion it emits a series of bleeps. These do not follow any particular pattern or frequency. The bleeps do not sound like those emitted when making entries on the keypad, they are of a slighly higher pitch.
I have not opened the control panel as yet and would appreciate any suggestions from your membership.
Check the log on the panel first and see if there are any faults listed. But I would also suggest that you have smoke detectors fitted and its actually the low battery warning on them.
If you are not sure how to check the log, download a user manual hereScantronic Website
Colin.
Could be the chime.
Enter your code and press NO, YES, YES and see what it tells you.
Service Engineer
My opinions may not reflect those of my employer, managers, colleagues, customers, friends, family or pet rabbit.
