Guest trickey Posted August 2, 2006 Posted August 2, 2006 hi can any body help iam looking for a manual for the above it addressable type control panel i need to loop learn devices etc many thank trickey Quote
morph Posted August 2, 2006 Posted August 2, 2006 "We do not give out Alarm Engineer/Installer manuals, to avoid offence please do not ask us to supply them" Quote
sparky999 Posted August 3, 2006 Posted August 3, 2006 hi can any body help iam looking for a manual for the above it addressable type control panel i need to loop learn devices etc many thank trickey You have a problem there. The AX1 uses the old Menvier 600 series detector with addressable base but I have added i maybe 2 devices of the newer 700 series addressable detector. Can be a problem I did have a manual somewhere but cannot lay my hands on it at the moment. Quote Peter Robinson Freelance M:07889038650
Guest jonnymac101 Posted August 5, 2006 Posted August 5, 2006 tricky .... if ure adding new devices ont the system and youve not had a chip upgrade it wont accept the new devices ... you can buy a new chip for about 300 quid (rip off ) BUT THJATS BIG COMPANYS FOR YA Quote
Guest atty Posted September 30, 2006 Posted September 30, 2006 hi can any body help iam looking for a manual for the above it addressable type control panel i need to loop learn devices etc many thank trickey Hello,i am an ex menvier engineer,you dont need a manual they are really easy to use,if you want to add new devices(700 series)which are a problem to get hold of,you will nee to upgrade panel software.The chip you need is called a poo chip!no im not joking!menvier will charge you Quote
esp-protocol Posted September 30, 2006 Posted September 30, 2006 hi can any body help iam looking for a manual for the above it addressable type control panel i need to loop learn devices etc many thank trickey Hello,i am an ex menvier engineer,you dont need a manual they are really easy to use,if you want to add new devices(700 series)which are a problem to get hold of,you will nee to upgrade panel software.The chip you need is called a poo chip!no im not joking!menvier will charge you Quote
Guest Posted October 1, 2006 Posted October 1, 2006 How about adding text ???And what about defender panels, can these be added to/maintained ? its an old beast you want text its either a marker pen or a label printer job . the front controls have 2 x 7 segment leds on them. I you've seen a Tan fire one its the same sort of set up. I'am sure menvier don't sell the software to anyone but may have "agents" Quote
F C E Posted October 1, 2006 Posted October 1, 2006 How about adding text ??? And what about defender panels, can these be added to/maintained ? its an old beast you want text its either a marker pen or a label printer job . the front controls have 2 x 7 segment leds on them. I you've seen a Tan fire one its the same sort of set up. I'am sure menvier don't sell the software to anyone but may have "agents" god the trusty defender the one u cant isolate loop sounders on (amazing technology ) Quote All comments in this post are my own views and do not necessarily reflect the views of my employer
esp-protocol Posted October 1, 2006 Posted October 1, 2006 Yep they're the ones. They also have batteries in the loop sounders themselves from memory..... Quote
Guest atty Posted October 2, 2006 Posted October 2, 2006 How about adding text ??? And what about defender panels, can these be added to/maintained ? its an old beast you want text its either a marker pen or a label printer job . the front controls have 2 x 7 segment leds on them. I you've seen a Tan fire one its the same sort of set up. I'am sure menvier don't sell the software to anyone but may have "agents" Quote
