Guest Mijmu1 Posted August 3, 2006 Posted August 3, 2006 Hi I was hoping someone could help me with this. I am trying to setup the programs 2 and 3 on the accenta G3. I go into engineer mode and follow the instructions in the manual to set zones 1, 2 and 3 (3 doors) to be in program 2. But when I try to activate that program it still activates prog 1. This is the steps I use to setup prog 2. PROG 9999 PROG 2 1 and then hit 1, 2 and 3 to select these 3 zones I then hit reset 4 times. When I activate the alarm and hit PROG and 2, I get a flat beep and the system defaults to prog 1 the pre-defined option. I can change PROG 1. PROG 2 and 3 hold the settings I configure but I cannot use then then I turn on the alarm. Can someone please tell me what I am missing here. I have asked a few installers here in Ireland but they havent used this system before.
amateurandy Posted August 3, 2006 Posted August 3, 2006 HiI was hoping someone could help me with this. I am trying to setup the programs 2 and 3 on the accenta G3. I go into engineer mode and follow the instructions in the manual to set zones 1, 2 and 3 (3 doors) to be in program 2. But when I try to activate that program it still activates prog 1. This is the steps I use to setup prog 2. PROG 9999 PROG 2 1 and then hit 1, 2 and 3 to select these 3 zones I then hit reset 4 times. When I activate the alarm and hit PROG and 2, I get a flat beep and the system defaults to prog 1 the pre-defined option. I can change PROG 1. PROG 2 and 3 hold the settings I configure but I cannot use then then I turn on the alarm. Can someone please tell me what I am missing here. I have asked a few installers here in Ireland but they havent used this system before. That's correct according to my manual, and it worked OK on my system.
FASTCAR Posted August 3, 2006 Posted August 3, 2006 Not my panel of choice..but..try changing the exit mode.
Guest Mijmu1 Posted August 3, 2006 Posted August 3, 2006 Not my panel of choice..but..try changing the exit mode. I havent change the exit mode, I will try that later today. I will set both to timed or silent.
sparkyred Posted August 3, 2006 Posted August 3, 2006 you need to programme prog 2 exit mode as a timed exit.
Guest Mijmu1 Posted August 4, 2006 Posted August 4, 2006 correct, if you do not program the exit time and type it will always default back to prog 1 Thanks for your help, that worked perfectly. Rgds Michael
