Guest duggz Posted August 4, 2006 Posted August 4, 2006 Hello All... I installed a Eurosec cp8+dialler in my 3 bed house a year ago. Just decided to actually program the part sets so I can go to bed and leave downstairs and garage armed. I can disable zones via the keypad but this is a pain every night. Now I have the installation manual but I can't get my head round it, If some kind soul could give me a clue in the right direction i'd be most grateful. ATB..... Duggz
FASTCAR Posted August 4, 2006 Posted August 4, 2006 If it is the led version , have a look at page 11 , there is a 2 digit code that determines how the zone behaves. eg zone 4 is a 12 hr zone removed in part set 1. Best to make a list of all zones , and decide how you want them to react in FULL and PART sets , then write the appropriate number at the side of it. Easy
Guest duggz Posted August 5, 2006 Posted August 5, 2006 FASTCAR said: If it is the led version , have a look at page 11 , there is a 2 digit code that determines how the zone behaves.eg zone 4 is a 12 hr zone removed in part set 1. Best to make a list of all zones , and decide how you want them to react in FULL and PART sets , then write the appropriate number at the side of it. Easy Thanks Mate... Put me on the right track.....case of so simple it was complicated MAYCO said: Or just use the idiot proof flow chart in the install manual to change each attribute and type as required. Sorry...Didn't see a flow chart in the manual... sorted now, thanks for your input
