Red Fox UK Posted August 5, 2006 Posted August 5, 2006 Hello There, Just wondering if anybody has had any expierience with self-fitting and buying the equipment to automate existing gates on a residential driveway? , Warren Red Fox | Hosting Affordable and Reliable UK Based Web Hosting
Red Fox UK Posted August 5, 2006 Author Posted August 5, 2006 I did find a few kits on the internet, just wondering if there were any "gotchas" that I need to watch out for... Other than that, they look pretty easy to install. Red Fox | Hosting Affordable and Reliable UK Based Web Hosting
Guest Posted August 5, 2006 Posted August 5, 2006 Dont forget the supplies to the control unit, the saftey beams, induction loops. How will visitors announce themselves. can you weld as well, or is it wooden gates. Came brackets need to be welded wotever as do Nice and FAAC. Is it heavy useage if so go to 24VDC motors. Easiest to fit is the Ferni range from Came, articulated arms and forgive even the worst hinge geometry, nice do a good equlivant too. Just make sure the gates run smooth and dont fall out of line. A stop is needed for both open and closed, you can use internal limit switches but its a fools game to depend on them. Apart from that its a stroll in the park. Unless you need leading edge safteys for errant children behind rolling gates or schools or i`ll shut up now.
Guest Posted August 6, 2006 Posted August 6, 2006 Give Simon a call he will sort you out with the right kit at the right price.Make sure you have all the measurements and dimensions of your gate before you call. I'll second that, excellent team to deal with.
Red Fox UK Posted August 6, 2006 Author Posted August 6, 2006 So you would recommend the above ground rams as opposed to the underground motors for small domestic gates? Red Fox | Hosting Affordable and Reliable UK Based Web Hosting
Nova-Security Posted August 6, 2006 Posted August 6, 2006 Warren, BFT at stockport, good kit and reliable if installed right. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest Posted August 6, 2006 Posted August 6, 2006 Small domestic gates use geared motors. For pure class use underground, but if gates already fitted use "rams".
secboy Posted August 6, 2006 Posted August 6, 2006 If you use came via gardiners which I've found to be good kit Andy their field support engineer will help commision new kit on site and came offer free installer training for their range !!!.
jnealon Posted August 6, 2006 Posted August 6, 2006 I've used the Pluto kit from Nice a few times. It might be called something else now but I have kits in at least 7 years now. www.realsecurity.ie
Mick Posted October 5, 2006 Posted October 5, 2006 A few words of caution when buying electric gate kits. I know one supplier who will do a hydraulic underground kit which includes remotes, control panel, photocells etc gor about
